Does anyone know if these are any good?
i have the exact kit in my car, but i only paid 26 quid for it locally, that postage is shocking!
its good enough, works, but you will still have to reverse with care, as the refresh rate of the sensors isnt as quick as you can reverse. When the indicator hits 00, and it beeps like mad, STOP cos your about 25-30 cm away from whatever it is your gonna hit!
conclusion, good kit, not too hard to fit, wires to the reverse light, but shop about for a cheaper price.
cheers!!
are they easy to fit?
not too bad, you just need to follow the instructions and do some simp,e maths to get them the right distance apart and all at the right heigh. A bit of masking tape will help you mark up. you need to install each sensor into a specific side, and then plug them into the specific socket. The hardest part would probably be finding a hole to get all the wiring into the boot area, but most car have some sort of vent, or grommet behind the buper somewhere, could even be on the side part. Once you done all that, the unit can tuck away behind the panel which covers the rear bulbs, which is also where you need to wire into the reverse light.
so its not too bad. just take your time.
