Hilux Rear Axle Needed
kinada
Anybody have a rear axle for a 1995 MK3 hilux double cab 4x4? The diff has been without oil and sounds bad. :( Do any other rear axles fit? Thanks
Im not sure about other rear axels fitting but i think your best bet for finding one is checking out the online breakers websites.
I will find out if other axles fit and let you know.
Gupster
www.hpoc.co.uk
Hilux Pickup Online Community
  • 9 years later...
HELP, l am in desperate need of a rear axel for my 1993 ln130 2.4 T/D, l,m not sure whats gone wrong, but when l try to
drive it, there is an almight bang coming from the rear axel, its as though the half shaft is coming away from the diff, and snappinback into place, l,ve been told it could be one of the teeth from the diff that may have broken off, and gets jammed
, then when under preasure moves, so releasing the half shaft to rotate, and thats what the very loud bang is that l hear
from the rear axel, please can anybody who has had this happen to them, get in touch and let me know what is happening
so l can get on with the repairs, other than this fault, the truck has been a faithful companion, with no problems what so ever...
Thank you..........
