Hi all;
I have just got a starlet GT (EP82) but it now has a suspect hg problem, so might need to replace it. I can get a standard toyota one ok from fensport, but i cant find anywhere that sells a HKS or TRD etc uprated gasket. Anyone know where i can get one from?
Thanks;
Harvey
Harvey, Don't use the TRD one mate it's thinner than stock and designed for the 4EFE none turbo engine. Best place over here to get one from is Dave @ www . starlet gt turbo . co .uk (remove the spaces).
Simon
Thanks for the info Simon. Yeah i noticed the TRD one is to raise CR on an NA one - not good on a GT especially as the head will prolly need prepping, increasing CR anyway!!!
I will check dave out, thanks again. I might just go stock though, as a toyota HG is about £35 (hg alone) where as for example, a pulsar GTiR HKS gasket is 200+!! So i doubt the starlet one is much cheaper :(
I think they are between £100 and £150 so yeah not cheap.
