Cant Lock The Car
vmail
Sometimes the Toyota fob will not lock the doors, but it has no problems unlocking the doors
I have checked to see if all of the doors are closed properly
My alarm fob is still able to lock the doors
the red leds still light up, will the Battery need changing, if so what size Battery do I need?
Hardly seems likely that it's the Battery if it still unlocks the doors.
Take it back to Toyota and ask. If you want a cheaper Battery, most markets have cheap Battery stalls. Just take the keyfob along and they'll sort it for you. :thumbsup:
Mines did that when it needed a Battery last - dunno the size, just take it to bits and take it to MrT (who will no doubt be too expensive, but almost definately have the thing in stock)
if it a CR2032 3V Battery I should be ok just got 25 of them for 13p each, Ill see if the problem goes away with the new Battery
Good luck. :thumbsup:
25 batteries? Sounds like you've done your own group buy. :D
I only wanted two at the time but they were £1.50 each at the local shop. Just got tolook for a small screwdriver
