Changing Engine Coolant
Jongbok
Hi. I am a Toyota 93 Corolla owner. I am trying to refill engine coolant. As in the manual, I found a radiator cap and a radiator plug, but couldn't find engine drain plug. Would you please let me know where it is? If I can see a picture about it, that would be great. Thank you in advance.
Don't have any specific info for you I'm afriad - but there aren't always drain plugs for the coolant. I've had a car before where you just had to undo the clip holding the bottom radiator hose onto the engine and pull the hose off to drain the engine, with the air bleed screws open and the coolant cap removed to let the coolant run out. Followed by lots of blowing into a specific hose and it was quite an effective way to drain the coolant :)
