Yaris Rear Lens
WGB
On an 02 yaris does anyone know if the rear light lens can be replaced with the light in situ or does it need to be removed first?
thanks
If you pop the plastic cover in the boot off, theres one 10mm bolt - thats what holds the whole lens in place. If its not been off before it feels like theres something else holding it - but there isnt its just gummed up with muck and the rubber seal.
When it does move it'll still be held on with the power leads so be gentle - disconnect these by twisting and off you go!
