Headlamp Covers
errrr
how do you get them off??
i've noticed two little plastic bits along the bottom, are these screws? (the top section of the cover appears to hook onto the remaining clips)
From memory you have to ease them off from the top first - open the bonnet and there should be two clips over each light with the clip fixed to rear of light and fitting through front face of cover - think if you push on middle of clip it will unhook from light and unclip allowing the front bit to unhook from cover - then you ease cover from light at top first and unhook the bottom hooks from the trim below the light.
Hope that make sense - does in my mind but looks odd written down :P
