O2 Sensors
rutland32
does anybody know what voltages the in and out o2 sensor voltages should be on a warm engine at tick over?
I have a 1.0 Gl
Assuming we are talking about the oxygen sensor ahead of the catalytic converter, the answer is 450mV with a voltmeter. However, it is very much more involved than a single number, read on...
How it works?
http://auto.howstuffworks.com/question257.htm
How to tell if the sensor itself is damaged?
Also the crucially important correct oxygen testing procedure.
http://makeashorterlink.com/?P53F228AC
http://makeashorterlink.com/?H64F238AC
This is just to show that using a voltmeter for the test is really a compromise; an oscilloscope is the better tool and its tracing looks like this:
http://www.picotech.com/auto/waveforms/lambda_zirconia.html
If the sensor is of the less common (but quicker and more accurate) variety of titania:
http://www.picotech.com/auto/waveforms/lambda_titania.html
Bee.
