Pas Problem On An Imported Mr2 Mk2 1991
The P/S light has come on; on the dash. The steering has become more tense. I've checked the Fluid level which is fine.
I'm aware that it could be the pump. I don't think it's the rack as the car still drives fine.
Is there a power steering belt that could have snapped ?
Is it still safe to drive ??!!
Thanks !
The pump is electric, and is in the front of the car.
No belts !
But yeah, it hould be ok to drive, just heavey steering
Thanks !
Its most likely the relay in the power steering ECU. You might be able to unstick the relay by switching the ignition on and off about 10 times before starting the engine.
:thumbsup: Known issue .. loads of posts about it ..
