Dump Valve Issues On St185
sweatyfox
Ive just bought a Bailey dump valve fitting kit for my GT4 and is states that the kit should only be used with a DV26 'D' dump valve and not a normal DV26.
What is the difference between a DV26 'D' and a normal DV26?
I ended up fitting a piston dumpvalve (no make) I got off eBay but im not sure if its quite right?
It works at low bost pressures although not that loud, and at high boos pressures I dont hear it at all :(
Also, if im driving along and let boost build up slightly, then ease of gass theres a bit of a jolt in deceleration, not smooth like usual, any ideas why?
Could it be that ive used a wrong pipe from the intake manifold? will post a pic shortly
Cheers,
Lawrence
Well at least you got shot of the bailey. They`re not that well liked. OK on escrot turbos apparently. :!Removed!:
vacuum connection looks ok. But you could try a different vacuum pipe to see if that makes a difference. Is the DV you`ve now fitted adjustable? Is there a sgrew and locknut anywhere on it? Have you got a pic? :thumbsup:
I havent got a pic of the dump valve at the moment, but where the small hose goes onto the top of it there is a nut where I might be able to take a spring out or something, but I wouldnt have thought its very adjustable.
Are their any good Make/Model of dump valves you can recommend? I'd like something loud.
Also if Im running 17psi will this affect the type of dump valve I need?
Thanks.
can you not find the picture on ebay? If you didn't buy it long ago then do a search for completed items, or they might be selling more the same
Ok, ive found a pic of one that looks Identical in every way.....
Dump Valve
I will post a pic of mine up later.
Looks a bit like a forge copy, Don`t think it`s adjustable. :unsure: Don`t try and dismantle it. You`ll have springs flying all over the place..... Trust me. I know. :crybaby:
Most DV`s are good for 20PSI+ However it may be of questionable quality. I`ve got a blitz duo sound jobbie thats quite nice (and adjustable). But HKS, GReddy or Forge are all very good. :thumbsup:
Thanks for the replys, would one of these be ok?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...60905%26fvi%3D1
Im a little confused about the flange tho, looks like it bolts straight onto the turbo? or can I just plug the round tube into where my existing one goes, and have the flanged section as the outlet?
Cheers
Not so simple i`m afraid. You`d have to have a matching flange fabricated somewhere on the inlet piping.side of the induction set up. If you`ve an air to air intercooler that would probably be the best place for it.
If you type 'how dump valves work' into google and have a read through some of the sites listed you`ll soon get a good idea of how they work, what they do and the best one to buy for your application. Incidentally. i reckon this is a nice bit of kit and very good price.
from Forge motorsport. :thumbsup:
Ok, I dont need the fitting kit as everything is already installed, so all I need is the dump valve, do you know if this one will work ok?
http://www.forgemotorsport.co.uk/content.a...product=FMDV004
Also are the forge dump valves nice & loud?
It should do. Give them a phone call. they`re a very helpful bunch of blokes. They should put you on the right track. :thumbsup:
Oh and if you`ve not done it already get rid of the insulation under the bonnet. Lots of advantages . You`ll let more heat out of the engine bay. The DV will sound louder, if thats what you want. And if you remove the sealing strips front and rear you`ll let more air through the engine bay.
