Help With Uneven Idling On 91 Celica
df_genius
I have just had my water pump and cam belt changed, and since then the idle has been really uneven, dropping to 600Rpm then I guess the anti-stall kicks in and picks it up to 900 then back down to 6. I have taken it back to the garage and they said it needs tuning and they have fitted the cam belt OK. It is fine when running, aside from pinking a little below 2000rpm. Before the work it was fine.
The car is an St182.
Any ideas? :(
