Hi - hope someone can help. The oil light (yellow one with the wavy line underneath) on our Estima Enima (1995 2.2 TD) started flashing and then went off again after a few miles. As we have just had a service could it be too much oil has been put in. :unsure:
Grateful for any help.
Julie b
Julie b
If you are that usure about the oil, it's best to check it yourself, it'll only take 5 minutes. But i'm pretty sure that over oiling would not cause the light to come on, it's designed to work the opposite way (lack of oil).
Check the oil to be on the safe side !!
Darryl
