Rattle From Behind Stereo
ahmedz123
i had a new stereo fitted using the single adaptor. recently iv noticed a rattling noise coming from the same area. mainly when i go over bumps or uneven surfaces. i have noticed one of the clip is broken on the actual panel that holds the stereo, heater vents etc in. this sticks out a bit from the rest of the dash. any ideas were the noise is coming from? also can you buy a replacement panel without buying the instruments?
