Thermostat Location...........?
saxokiller
Hello guys,Can anyone please tell me where the stat is located on a 1992 corolla gti?i need to change asap
Max Res Trev
It is located on top of the gearbox in a alloy housing, which the bottom coolant hose connects to!
The housing is easy to spot, it is held onto the top of the gearbox via 2 12mm headed nuts, and also has a sensor sat in the top! You will know what i mean when you see it! ;)
Cheers dude,your a star!!!!!! i will sort it today thanx for your help!
Max Res Saxokiller
