Yaris
viperroom_112
In light of recent weather and s***y roads around here I invested in some universal fog lights ! With remote turn on kit ! What do you guys think ! The only other problem is they are not wired up yet because i simply do not have a clue how to do it ! Or were to place the remote box? Any help would be appreciated !
David
sorry about photo it was bright today
http://i8.photobucket.com/albums/a38/viper...12/DSC00838.jpg
wirings simple
you should have a realy which is activated by a switch and then a main load from the batter to the lights
look up 'Bosch relay wiring' on google thats the way to do it :yes:
as for the remote thig ive got no idea?
looks good to me :D Makes the bumper look wide which is nice as imo that grill is too far in the middle. But yeah looks good mounted into the bumper but thats an awesome attempt for a less permanent solution! :D Impressed!
Im assuming the remote box is a relay?
As Jaxx said its a case of tapping into the sidelight circuit (fogs should only be able to come on with side light) and then getting power to the lights. Done this many times with older cars - the trick is to measure out roughly all the wire and install it without actually running the cables in to start with.
That way when the inevitable dry joints annoy the pants off you - you can just replace that peice or joint.
Also - at this time of year - start early in the morning - daylight is a major requirement!
your telling me, i didnt get in home till 8 last time i had hotaches like owt wen i got in
