Wet Feet A No Cost Option?
GEN6GT
:( Had an '90's MR2 that leaked water into offside cabin footwell. Thought I'd have a look in my G6 just for the fun of it. You got it, damp patch right under the gas pedal!! In the MR2 water got in around the top/front window seal, down the A post and into the well. Anyone had the same and found the seat of the leak???
Does yours have a factory sunroof? Sometimes the drain holes can get blocked allowing water to back up and enter the car.
;) Thanks, good idea! Yes it does have a sunroof. I'll shoot some water around the drain holes and see where it turns up!!
I had a similar problem with mine in the autumn when it was parked outside. I also smeared some vaseline around the rubber seal. This causes the seal to swell slightly and give a better seal. Allegedly. :thumbsup:
