Gen 6 Headlight Unit
algonquin
I have a Gen 6. The rubber seal on the outer headlight unit had pulled out of one of the spring retaining clips. So I decided to put it back in place. The clip is in the 10 o'clock position and difficult to reach. When easing it off with a screwdriver, of course it flipped somewhere in the headlight mounting. How do I remove the unit after taking the bulbs out? All I can see is a top bolt holding the unit to the cross member.
Bumper off methinks :(
stick the rubbers on with a glue of some kind , they wear at the clips and snap at some point anyways .
