Warning Lights - Landcruiser
Michael Mick
Hi
Could someone advise me, I have a 1990 Landcruiser 2.4td 3 door and when it is started all the warning lights come on and remain on. Everything seems to be fine but they will not go off, has anyone come accross this or what could be causing this.
Michael.
This is usually a sign that the alternator is on it's way out, put a volt meter across the Battery with the engine running at about 2000 rpm, it should show around 13 + volts if it's ok.
Hi
Thanks for that Andy not as serous as it looks then.
cheers
Michael
Hi
Michael.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
