Went to Halfords to replace the missing aerial but none of their universal fixtures would fit. Can any tell me the model number or where i can find one? The plastic mount on the pillar between the drivers door and the windscreen is ok, i just need the aerial.
Cheers,
Craig.
Mine was the same when i bought my Seo. You'll find that the aerial from a starlet or a carina fits just fine. So head off to your local scrappies. Although I ended up going to toyota and getting a new aerial - about £28 inc VAT. Fitting was not too bad but one tricky bit was feeding the cable down the pillar and out the bottom :blink:. Patience req'd :D
Cheers mate i'll give it a go.. because all the cables and stuff look to be attached i was hoping i could just screw one in. I guess it was just wishful thinking!! Looks like i have a project for the weekend :crybaby:
