Stiffer Anti-roll Bars
K19NE G
If so, which ones did you go for (ie. 24mm diameter), and what are the downsides? ie. does it make the car more bumpy over uneven ground or does it just make the car handle better round corners? :blink:
Cheers! :thumbsup:
Cheers! :thumbsup:
im planning to get anti roll bars for my car aswell, im planning to get them from fensport, they r selling whiteline 24mm diameter, which is bout correct for the car and for an FF car bcos if its too thick the car could b too hard and could probably quite easily oversteer. so i say 24mm. but im no expert, hopefully some1 that knows more bout this could help both of us. but im pretty sure fensport ones should b fine. im assuming ur gna feel bumps a lot more aswell. but that doesnt bother me, im fitting them for me and to improve the handling. ahahaha sod the passengers they can hav a dead back side after each ride doesnt bother me. ahahaha :P
I knew i posted about these before.. done a quick search for you.. hope you find it usefull.
Following from a topic in the Yaris section,here
i thought i'd post this in general so that those who don't read the Yaris section can benefit from the info there.
Q. What do swaybars do?
A. Swaybars.. or Anti-Roll bars as they are called in the UK (Swaybars is the Aussie name).. link the 2 corners of the suspension together.. when you corner, and your car tries to go down on one side, the car resists this rolling tendancy (bodyroll).
Most cars are designed to slightly understeer.. as this is easier for the average driver to cope with, rather than having oversteer where the back end can step out and catch you by surprise.
The stiffness in the rear is increased, which loads the rear wheels uneavenly and reduces their grip a little, this allows the front to be more evenly loaded and gives a lot more front end grip. Remember.. it's the front that steers the car.
A rear anti-roll bar on a FWD car will give better traction through the car and generally reduce understeer.
Also.. on a car that has been lowered quite a bit (more than 30mm) an uprated rollbar will stop the suspension from bottoming out.. ever seen a lowered car "bounce" round corners and bends?.. this is because of the bodyroll. the car leans over and compresses the suspension, then when the car hits undulations and bumps in the road, the wheel leaves the ground and the car looses grips because it has ran out of suspension travel. an uprated antiroll bar goes a long way of preventing this and keeps the suspension working as it should be.
This must be one of the best mods you can do to improove the handling of your car, and i would (after speeking to Yob on many occassions) highly recommend getting them before lowering a car.
:thumbsup:
Get a list of dealers in the UK from http://www.whitelineautomotive.co.uk/ There is also a lot more information on Swaybars and all other types of suspension parts in the Tech Talk FAQ's section
All it is is an uprated antiroll bar. I have added links to more info in my post above.
For the lazy amoung you..
Shocks faq.
Springs faq.
swaybars
Wheel Allignment
Wheels and Tyres
Everything else
There is a LOT of good information in these links.. some of which will open your eyes to the importance of certain aspects of your modified (and standard) car.. well worth a read.. and remember, the info is from a company that designs, builds and supplies both the parts AND the training to the worlds leading retailers (the training comes into it so that the retailer can give you the correct information on the parts you inquire about)
If any of the mods feel this inappropriat for whatever reason.. feel free to delete it.. if not, delete this line.
Cheers! :thumbsup:
I wouldn't mind if the car would step out at the back going into corners instead of 'nosing' straight on! :D A bit of FWD drifting :lol:
:thumbsup:
So I'm gathering from all this that a rear anti-roll bar would dramatically help the T Sport in cornering! Only question I now have is, would I go for a fixed one or an adjustable? (Does this depend on whether the car is lowered or not?)
Thanks for your replies by the way! :thumbsup:
Cheers! :thumbsup:
:thumbsup:
Well the adjusted ones u can set the stiffness, so its up to u if u want to get an adjusted one or not. im not planning to, since i dnt hav a t sport. Yes the rear would help aswell. Now i can wait for some1 to fit it bfor me now and u can tell me wot the difference are. ahahahaha
