Sticky Problem
gordypix
What is the best way to remove the 'dealer' sticker from the rear window and all the gunk it leaves behind........??
Need to put my TOC sticker in its place.... :thumbsup:
autoglym intensive tar remover :D retails at about £4
of course u could use any other household de-gunker lying about
Is that OK to use on the inside of the rear window....Sounds like something to remove the road tar deposits on bodywork........
Just becarful of the heated element, do not use any sharp tools as you risk braking the line.
Dan
gordy,
i'm reading the back of the bottle now and it has instructions for 'INTERIOR'. However it is concerned with oil based stains in carpet and fabrics... although I can't see why it wouldn't work on removing the glue from your rear window...
you'd just have to wipe it off and polish when ur done i suppose, try some household things before u go out and buy this stuff first m8
as dan suggests just got to be a little careful :)
Hey guys - DONE IT. B)
Funnily enough - after being on the rear window for eons & eons the sticker peeled off in one piece leaving just a small residue that I zapped with bog-standard window cleaner....Prob solved.
Thanks anyhow..... :thumbsup:
The car is now displaying the TOC sticker...... :thumbsup:
Gordy
All the BEST cars have one :P :P :P
