Just got a Tom Tom One and thought other Aygo owners might be interested to know that there is quite a bit of flexibility in the interior dash with decent size grooves between panels.
So if you locate it on the screen just to the right of the driver (RHD) then you can tuck the power lead into the side of the steering column, under the bottom, across into the coin holder (bundle excess lead here) and then into the 12 v Supply.
Result is a small lead into the unit and a short bit into the 12 V with the rest of the lead concealed.
Not quite hard wired but a very neat / easy job, leaving a pretty professional look.
