Air Con Control Panel
richiekuk
Hi All
Yet another little niggle with my st205 gt4. The air con control panel (beneath the radio) is a bit dodgy.
I was driving at night and none of it was lit up, when the headlights were on. After a while the top row of buttons lit up, then after another while the next row lit up and again for the rest of it.
Drove it again yesterday at night, and the same thing happened.
Any ideas?
Richie K
take it apart, replace the bulbs and it will probably sort itself lol
these cars have personallities of their own you just have to get used to them, then you's will get along just fine :D
check my sticky in the celica section " how to change air con lights "
its possible the multi plug isnt pushed in fully or the bulb holders just need a bit of a twist , you will need to order the bulbs from mr.t also if you want new ones - good luck
