Mrs Toyota Sequential Manual Transmission
shaunattard
Hi i have a problem i am hoping that someone would give me some help or advise which would help solve my problem i have a
Toyots mr2 Engine: 1790cc
Engine number :4249
Chassis number: ZZW300028819
Year of manufacture 2000
I recently had the engine overhauled when that was beign done they had to disconnect the Battery and it seems to have lost the memory on the acclerator cpu. When you use the car unless you disconect the Battery and reconnect it you do not have acclerator control You need a program or soultion to program the "Throttle Motor", over here in Malta not even Toyota the main dealers had an idea on how to solve my problem would anyone out there who may have some information for me regarding this kind of problem contact me.
Shaun Attard -: archangelonero@hotmail.com
  • 2 years later...
Engine number :4249
I recently had the engine overhauled when that was beign done they had to disconnect the battery and it seems to have lost the memory on the acclerator cpu. When you use the car unless you disconect the battery and reconnect it you do not have acclerator control You need a program or soultion to program the "Throttle Motor", over here in Malta not even Toyota the main dealers had an idea on how to solve my problem would anyone out there who may have some information for me regarding this kind of problem contact me.
have u sort it out? diagnostic check can clear off the trouble codes easliy and should be returning into normal operation unless ure throttel body is dirty clogged with carbons..
anyhow i was wondering at the sequential pump what kind of fluid are you using? i have the mannual book but its japanese i cant even figure it out...
pls advice me...
rockerfella174
