Tyre Pressure
clairekreetzer
Hi!
I have a 95 Celica GT. Brought new alloy wheels & tyres for it and had them fitted at the weekend. I wonder if anyone can tell help me with the correct tyre pressure. At the moment i'm getting a really bumpy ride and it doesn't really feel right!
Tyres are: 215/40/17
Claire
About 30 / 32 PSI all round should be fine.
When I got my new rims, the first drive was rubbish. Checked the pressures, and they were anything from 45 to 22 (I have a lot of issues with POTN, and won't be going back there). So make sure the pressures are at least even all the way around as well. :thumbsup:
Oh, and what size tyre have you come from? There will be a noticable difference in bumpyness if the tyre profile has reduced...
keep the same pressure as the stock wheels , its on a sticker on the drivers door panel - tyre pressures are car weight based and not wheel tyre size based.
iirc the gt is 32 fronts and 34 psi in the rears for 1 person , a full load it rises considerably
also a 40 tyre wall is really small , so comfort will suffer due to its hardness - ie- the smaller the tyre wall the less give and shock resistence it will have
You've just put 17" wheels on. Assuming your old wheels were smaller, then you can expect a harsher ride. Big wheels are for cosmetic purposes only, pretty much everything else about them is bad. :thumbsup:
Tyre pressures should be around 30-35 pounds, depending on the tyres themselves, and how you want to balance the front-rear grip.
