:huh: Can anyone tell me how the MP3 player works in the new Rav 4, i'm told by the dealer it's not an actual MP3 but a recordable disc that stores MP3 tracks and will only play in the cars Cd Player and not on any other type of CD player, is this correct.
In a nutshell, with the use of your PC and Burning Software (Nero or Roxio etc) you can place music files which are in mp3 format on to a CD-R Disc which you can pick up in Supermarkets or on the net in packs of 10 or more.
The burning software does all the necessary you just have to pick which music files you want and because it’s in mp3 format you should be able to burn a 140+ tracks on to a 700mb CD-R disc depending on the mp3 quality (kbps) and the length of songs, then once it burns successfully you can listen to the CD in the RAV4 CD player or any Car CD player and Home Hi-fi as long as it has the mp3 symbol showing it can playback mp3 format music.
The burning software does all the necessary you just have to pick which music files you want and because it’s in mp3 format you should be able to burn a 140+ tracks on to a 700mb CD-R disc depending on the mp3 quality (kbps) and the length of songs, then once it burns successfully you can listen to the CD in the RAV4 CD player or any Car CD player and Home Hi-fi as long as it has the mp3 symbol showing it can playback mp3 format Music.
Thanks for that, it becomes clearer now.
