Whiteline Arb's
Mr Morse
Fensport do whiteline products.
Never fitted them to mine, but if you were to add a rear swaybar it will stop the bodyroll, make the car have less understeer (might even ecourage oversteer a little) and make the front end more responsive when cornering.. a great modification.
Anyone fitted these?
Where to buy?
Awesome parts !! I have fitted these to my 1987 Camry 16v estate, then my 3.0V6 Camry and now my Ae92 Corolla. Fwd and 4wd cars need a stiffer rear bar that reduces the roll and stops the back sitting down in corners. The car will understeer less, feel tauter, and be the best mod per pound you buy. ( I make sure there is always one available when I buy my next Toyota !! ) Read the review section on www.whiteline.com.au. You can normally download a PDF file of the bits for your car. You can e-mail me on davef@demon-tweeks.co.uk for prices if you want
Q. What do swaybars do?
A. Swaybars.. or Anti-Roll bars as they are called in the UK (Swaybars is the Aussie name).. link the 2 corners of the suspension together.. when you corner, and your car tries to go down on one side, the car resists this rolling tendancy (bodyroll).
Most cars are designed to slightly understeer.. as this is easier for the average driver to cope with, rather than having oversteer where the back end can step out and catch you by surprise.
The stiffness in the rear is increased, which loads the rear wheels uneavenly and reduces their grip a little, this allows the front to be more evenly loaded and gives a lot more front end grip. Remember.. it's the front that steers the car.
A rear anti-roll bar on a FWD car will give better traction through the car and generally reduce understeer.
Also.. on a car that has been lowered quite a bit (more than 30mm) an uprated rollbar will stop the suspension from bottoming out.. ever seen a lowered car "bounce" round corners and bends?.. this is because of the bodyroll. the car leans over and compresses the suspension, then when the car hits undulations and bumps in the road, the wheel leaves the ground and the car looses grips because it has ran out of suspension travel. an uprated antiroll bar goes a long way of preventing this and keeps the suspension working as it should be.
This must be one of the best mods you can do to improove the handling of your car, and i would (after speeking to Yob on many occassions) highly recommend getting them before lowering a car.
:thumbsup:
Get a list of dealers in the UK from http://www.whitelineautomotive.co.uk/ There is also a lot more information on Swaybars and all other types of suspension parts in the Tech Talk FAQ's section
All it is is an uprated antiroll bar. I have added links to more info in my post above.
For the lazy amoung you..
Shocks faq.
Springs faq.
swaybars
Wheel Allignment
Wheels and Tyres
Everything else
There is a LOT of good information in these links.. some of which will open your eyes to the importance of certain aspects of your modified (and standard) car.. well worth a read.. and remember, the info is from a company that designs, builds and supplies both the parts AND the training to the worlds leading retailers (the training comes into it so that the retailer can give you the correct information on the parts you inquire about)
Both the above posts might help too..
Dave, have you ever dealt with Yob Geevers, whe runs the Whiteline place in Dalgety Bay in Fife, Scotland.. top bloke and really knows his stuff.
