Second Service
reece
i cant remember fully, think they changed all the fluids because i told them not
to do my brake flulid [ due to me having Castrol srf in mine ]
think i paid around £180 but i'll check through my service stuff and tell you for defo later.
Do you need to take a wheel or wheels off to change the brake fluid? How is it bled from the system?
Are the spark plugs checked?
Nope - there are bleed nipples accessable from under the car. You open the brake fluid resevoir and use a bleeding kit or just pressure each corner (diagonally) useing someone else to pump the pedal - then top up.
Spark plugs should be checked I think ..
Just got back from my 10k service this evening and got the paperwork in front of me, so here's a few bits from the 20k (it's on the same sheet)...
Replace Battery in remote locking.
Check valve clearance (audibly with stethoscope).
Check and inspect fuel cap.
Check power-steering fluid level.
Check coolant level and strength - report.
Inspect spark plugs. Replace at 40,000 miles or 4 years (whichever is sooner).
Inspect operation of charcoal canister - every 2 years or 30,000 miles (whichever is sooner).
Check and inspect fuel lines, connections and vapour control.
Full 4-wheel alignment check - extra charge for adjustment.
Not a full list but some of the extra things that are done at 20k. :thumbsup:
i need to go and have a word with the garage that did my service a couple of weeks ago. the brakes dont feel as good as they did before it went in. so i suspect that they changed the fluid. even tho they fitted the brakes for me 4 months ago and i gave them the motal brake fluid <_<
Interesting ... I never did get my plugs changed by MrT despite being well over 60k! When I asked them about when they'd need doing they said not to worry!
(its ok I got Denso Iridiums around 70k)
