Caraudio Upgrade
Sérgio Barros
In a few weeks my Yaris have a new sound. :D
The sound will be instaled by a juri of IASCA. :thumbsup:
These are the components:
Rádio Alpine 9853R
Speakers 3 separate ways DLS Iridium 6.3
Amplificador DLS A7 The Big Five
Subwoofer Diamond
Wow that is a beast of an amp! You decided where you gona put all the Speakers? They all the right size? Hope it goes well and keep us updated!
It´s easy.
The woofer in the doors.
The medium in the tablier
The tweeters in the pilar
Yeah may need some adapters for them to fit though as if the hole isn't the same size as the speaker it will fall straight through! If your getting an audio place to fit it for you though they should fabricate any additional bits needed :D
The Speakers DLS Iridium 6.3
Speaker type : 3-way system
Woofer size : 16,5 cm (6,5")
Midrange size : 75 mm (3")
Power handling capacity : 100 W RMS / 160 W max
Tweeter : 28 mm (1,1") tweeter
Sensitivity : 91 dB (1W/1m)
Magnet size woofer : 85mm (3,35") Hybrid ferrite/neodymium
Magnet size midrange : 80 mm (3,15") neodymium
Outer diameter of woofer / midrange : 165 mm (6,5") / 120 mm (4,72")
Installation depth of woofer / midrange : 65 mm ( 2,56") / 35 mm (1,38")
Mounting hole of woofer / midrange : 140 mm (5,5") / 95 mm (3,74")
Crossover : Box filters, one for midrange and one for bass/tweeter
The amplifier DLS A7
ULTIMATE A7 - The Big Five, 4 x 60 W + 1 x 300W
RMS output per channel at 13,8 volts, 20 Hz - 20 kHz , < 0,1% distortion.
Mode : AB
Number of channels : 5
Output power in 4 ohm : 4 x 60 W
The stereo channels can be connected in bridge mode giving a power of 2 x 200 W RMS
Output power in 2 ohm : 4 x 100 W
Mono channel, output power in 4 ohm : 300 W
Mono channel, output power in 2 ohm : 440 W
Mono channel, output power in 1 ohm : 600 W
S / N ratio, A-weighted : > 100 dB
Damping factor : > 200
Input impedance : > 10 kohm
Input sensitivity, variable : 0,3 - 7 V
Filter ch. 1 & 2 : Highpass: 80 - 400 Hz / 1,6 - 8 kHz (x20)
Filter ch. 3 & 4 : Highpass: 80 - 400 Hz. Lowpass 0,3 - 4 kHz / 3 - 40 kHz (x10)
Filters mono sub channel : Lowpass: 50-125 Hz.
Terminal for external cooling fan : Yes
Phase control : 0-180 degrees continuously
Remote sub level control with phase shift : Yes
Dual DC-inputs : No
Current draw, idle : 1,1 A
Current draw, maximum : 120 A
Dimensions W x D x H : 605 x 240 x 73 mm (23,82 x 9,45 x 2,87 inch)
Weight : 8,1 kg ( 17,86 lb)
Yeah there will need to be adapters for those Speakers as i thought but im sure the audio shop will do that for you! I haven't heard of the make of these Speakers before so tell us if they sound any good when installed!
Woody27
The original size for the Speakers in the door are 13 cm (5,25")
In the last upgrade I take off the original Speakers and I put a woofer with size 16,5 cm (6,5"). In that time the man put it on a adapter in the door. ;)
So, I will not need to be adapters for those Speakers. :thumbsup:
