St205 Alloy Wheels Please Help
andyGT4
i was wondering if any body can help me do weels of a imprezza fit on my celica gt4 st205 if not what wheels do apart from celica gt4 ones please help thanks it mite seem like a daft question
look in gt4oc general section for a full list of wheels that fit.
if you go to rochford tyres website and search for wheels to fit a scumbie it will give you the offsets etc , compare them to that of the st205 and you should have an answer.
hi dont know if this helps but i tried a set of scooby alloys on my st205 and they did not clear the caliper(the stud patten seemed the same )
As above. Basically the offset puts scooby wheels too close to the body of the car. Which will cause major problems on the ST205 because of the mahoosive stoppers. The stud pattern is indeed the same but iirc the centre bore is wrong too. Needs adaptor rings. So all in all the answer would be NO. ;)
