Mkiii Supra Turbo, Manual Gearbox Conversion Kit!
Karma Supra
R154 Supra gearbox, with ball housing and rear mount that has had oly 8 days use!!
All flaps, covers and braces included.
Manual turbo prop shaft, clutch slave cylinder.
Also included is the manual shifter, and manual 7M-GTE ECU.
Unsure what is involved in the conversion???? Look here!!!
You will need a manual clutch pedal and mount/master cylinder and a manual brake pedal, a flywheel and clutch. Everything else is included. I paid £700 for the entire kit when desperate, I am offering it now for £350.
