Missfire!
ibrokeit
:wacko: would resetting ecu possibly cure a missfire ? plugsand leads changed,new fuel filter fitted
Unlikely, But always worth a try. :yes: Did you do the dizzy and rotor arm as well? :unsure:
If that doesn`t work you might want to change the ignitor. I think someone on here has a spare. :unsure: Or the usual breakers are a source. :thumbsup:
changed the lot .... but ....dashboard lit up like a christmastree tonight oil light , ecu light , and most important ,,,, Battery light ,, looks like my alternators gone awol
