Carina Idle Speed
ptm555
Hi all
Recently a friend of mine replaced the spark plugs in my 93 Carina for me. Its done 129k miles! What an achievement! (original clutch!)
anyway, ever since then the idle speed has fluctuated when the car is stationary. Does anyone have any idea as to what may be causing this? Could it be the air filter?
Any responses would be greatly appreciated
Has he fitted the correct plugs? Are the Plugs correctly gapped?
Assuming that the engine is the lean burn type (4A-FE or 7A-FE), he should have fitted Platinum Tipped plugs (they cost about £30-35 a set).
This may be causing the uneven tickover.
When a fault develops directly after a new part has been fitted/replaced always suspect the new part.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
