Door Trims
saggyass
:help: door trims on my carina e, are coming away from door.
can anyone suggest a fixing solution to fix problem
thanks
mike
thanks
mike
Mine are doing the same thing.
I see the previous owner tried using double sided sticky pads which was a useless idea as the trim is fairly heavy duty and is even difficult to hold against the car body with my hand.
3M Double sided Tape will do it,do an eBay search ;) . If you want to remove them after you might have problem though.......
Go to the dealer and order new plastic plugs and replace them all, done it with mine cost me around 5 euro's. So even cheaper then decent tape :lol:
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
