adjustable suspension - WHEN DO I USE IT , IN WHAT CIRCUMSTANCES ??
is it best to drive in soft mode for every day driving , and use hard when loaded or towing ??? or the opposite way round . thanks . :help:
how does it work anyways , are the dampers hydraulic ????
Just use it when you feel the need, but it's best in high winds or when you have a lot of weight in the back, motorways and towing are other times when you need it.
The switch operates a small motor on the top of the shocker, it turns the main shaft about 90 deg to make it harder.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
