i have a 98 EP91 starlet and the dash digita clock goes on and off what could be up. Also the dash lights for the left where the fuel gauge is dont work is this a big operation to change the bulb? can i fix the clock myself?
thanks
kigo
clock - depends whats wrong with it. I have a spare if it helps.
Taking instrument panel out to change a bulb isn't too hard.
the speedo bulbs are easy, take the surround around the cluster out, and then undo the three screws which hold in the cluster, take the clear and black dial surrounds off and then you can get your hand round the back to change them... its easier than taking the damn thing out.
Rich.
