Jvc Kd-avx1
Andypr
:D Hi i'm thinking of getting the JVC KD-AVX1 it the one with the 3"screen,i seen one before christmas and was very tempted but at £600 its a lot,so i just went on the web and found it for £319 so i just might get it.has anyone got one?Also a couple of months ago i seeen a yaris with a aftermarket headunit in it fitted in the coin slot but the toyota factor head unit still WORKED as it was still displaying the time and temp on it,has anyone tryed this before as i see it as the best of both worlds. :help:
I've got an aftermarket headunit and my temp and time still works! :yes::thumbsup:
My tape player doesn't work anymore though! :rolleyes:
most head unit's will work and fit, the display with the temperature will work, as it's a different connector to the head unit no matter if you put it in the coin slot or get the complete works (new fascia and din unit)
To fire up the new headunit you use the wiring that goes to the standard cd/tape player, so the temp display etc still works, it will just be the radio/cd/tape section on the display that won't work.
that is a nice looking headunit
just seems a bit of a gimmick, and i dont rate JVC that well
the AVX 2 is out soon mate. Much better set up, should be about in a couple of weeks :)
