2001 Vvti Wheels +
hi all,
I have a 2001 corolla vvti 1.4... Does anybody know what the exact standard wheel spec for this car is as i'm looking to change the rims...I know they're 14", 4 stud. What else do I need to know (bore size, stud separation etc.)?
Also, coughing and spluttering sometimes with engine light coming on now and again. It was diagnosed as the lambda sensor, but the garage said there was only 60% chance it could be this. Has anybody had same problem or know what else it could be? It's like looking for a needle in a hay stack!
:help:
Year - 85 to 01 PCD - 4x100 Offset - 35 to 45 Bore - 54.1
Unplug the lambda sensor and clean up the connectors,and give a splash of WD40 might solve the problem, worked for me in my old Carina.
thanks davy
I managed to get a second hand lamda sensor from a scrap yard for £35 and £10 to get it fitted! (£130 +VAT exc fitting new)....seems to have done the trick!!
better than Toyota's diagnostic for a new £700 ECU!
My love for the car has been rekindled...they're such good cars
