Celica Lowering
Cexy_Ratt
I lowered my 91 celica bu 30 mm on fensport springs at the weekend, with new kyb gas shocks. It seems to be sitting a little high on the passenger front side. Any suggestions why this could be, also the steering is now a lot to the right when going straight, i am thinking this could be becuase of the suspension sitting high?
any ideas much appreciated, i am going to take the leg off at the weekend and re-seat it again i think
Yeah it sounds like it's not sitting right - I wouldn't drive it like that until you've fixed it though
Yep have a look at it. Sounds as though a spring might not be seated properly, make sure you are happy with the top mount as well. It's very unlikely but if you cant find anything obvious check to ensure the ram works on the shocky, it may be sticky.
like Sotal said I would not be keen on driving it until you get a chance to look at it. let us know what you find
I have had a quick look, everything seems ok, but will find out for defo at the weekend. It is sitting better now, thinking it may be a little high on the passenger front side , because no one sits int he passenger side usually, just me in the drivers seat?
