Hiya,
I am a new member just purchased 1993 model estima. Running lovely for an olden! I am having trouble reading in km rather than mph is thisstandard for imported vehicle I just don't want to be driving thinking I am within the speed limit in km and then realise it has been changed.
I have also noticed a small gadget by the righthand side of the drivers dashboard situated below the steering wheel it has min & max readings on it, havent a clue what the :ffs: is! Hope you can help me.
First off, you need to find out if the speedo is cable or eletric, then get a "speed de-limiter" .. it converts the kmph to mph .. they are about £30 (but some are over a ton).
It's a doddle to fit .. if it's cable, you have an adaptor off your g'box, if it's eletric, 4 wires to solder to your ECU.
Get a pic of the Max/Min thing and we'll have a guess.
