Damn Scraping
cmarshall
Why o why does it still scrape. The front drivers side always scrapes i have raised the front and it still does it only on my side, is the camber out, is it my fat ***** or could it be something else?
duno try setin it stiffer on that side i always found it worse that side think the main engine weight is that side so that may be why
Cheers lee, im getting my wheel alignment and camber done professionally later if that dosent sort it i will have to stiffen that side or raise the lot
Its just because i changed my wheels yesterday, yours should be fine chris! Phoned kwik fit, they dont do camber, GREAT!!!!
Most Kwakfit style places wont touch a lowered car - the only place I use now for either the yaris or mr2 has sunken ramps. You drive onto the ramp (which is in dropped into the floor) and it raises out of the floor - no scraping. My place does a free check but will do four wheel tracking for 15quid using their laser system.
Sorted got the wheel alignement done at Protyre, the camber was fine and all is good :D
