Ipod Griffin Smartdeck Connector Problems
jdmartin
Hi all.
I'm having problems using a Griffin SmartDeck iPod tape cassette adaptor with my Avensis. I put the adaptor in and the tape sounds like it is fast forwarding, the iPod goes from Pause/Play/Pause/Play a few times and then the tape ejects.
Has anyone any experience of this?
Griffin support say:
"Many times there is a special procedure to use when using a cassette adapter (rather than a conventional music cassette). On my Chevy Trailblazer you need to press the cassette button for 5-seconds while the radio is off. The word "ready" will appear and then you can install the cassette. If you don't do this, then the adapter will be ejected after 2 or 3 seconds of play."
There appears to be no such feature on the Avensis. Does anyone know?
Never liked those cassette adaptors. Looks like the tape player just swallowed a mouse with a long tail. Not to mention all that wiring. Do you actually get digital sound out of it? :(
I'm using a £4.99 cassette from Maplin. The wire is looped behind the facia console and into the centre armrest. No wires dangling. Took just 5 minutes to put in place. The sound is excellent. Significantly better than a tape. The FM modulator I had previously was a total waste of money!!!
I think your Griffin must be faulty? Take it back.
The tape adapter doesn't give digital sound but should be better than the iTrip I currently have and cheaper than a proper built-in solution.
The SmartDock allows you to control the iPod via the tape controls, such as FF to go to next track etc.
I think I need to send it back and get a normal one!
