Temperature Display
Khan B
I was out of country for two weeks and had to park my Avensis in an open car park during the time. On return I found that the temperature display is showing incorrect display. On a bright sunny day when outside temp was 10 degrees, it is showing -12 degress. :( Any ideas as to what the reason could be and resolution for it.
thanks in advance.
i'm sure i read somewhere on here, that it'll give a wrong reading if the sensor ain't connected propely
thanks in advance.
Temperature sensors are often located in the passenger wing mirror these days. Perhaps its had a knock while you were away from the car. The get fragile over time and suffer from water ingress so you probably need a replacement. You will probably find the Air Con doesn't work anymore :-(
This happened to me on the day I was selling my Ibiza. I went to Halfords to buy a new Battery just to be fair to the buyer. While I was paying for it I saw a car hit my mirror and not stop. When I drove home the air wouldn't work so I had a tough time explaining to the buyer why the air wasn't working.
Regards
Derek
