Hks Coilovers!
Ryan1985
Okay, the time has come to try and sell my coilovers.
Good bits
All (apart from one) shock absorbers are fine as are the springs. This kit lowers from standard ride height to about -80mm.
Bad bit
If you're looking from the back of the car, the rear shock absorber on the LHS is burst and cannot be repaired (apparently).
These would be ideal for any T-Sport owner as they would need new rear shocks anyway!
Gimme some (sensible) offers! :thumbsup:
Another picture, that's as clean as I can get them!
:thumbsup:
Retail is apparently around the £1000 mark. Fitting should be about £80-£140, it depends where you live really. Remember you'd need new rear shocks. :thumbsup:
Bump, you can get these from me at JAE so no delivery costs or need to collect! :thumbsup:
  • 4 months later...
I'm not sure, you can't get the same shocks anymore but you can get other HKS rear shocks or you could just get some Koni rear shocks. :)
Give me a PM if you want them mate, I might let them go cheap just to get rid! :thumbsup:
Ryan you got any kind of idea what kinda money you want for them? I could be interested depending on the price see :P
  • 2 months later...
I wasn't that bothered about them going. I was waiting for someone who was sensible enough to offer me what they are worth! :thumbsup:
Just a note but there not shocks their dampers.
Surely shock absorbers and dampers are the same thing?
Matty, I'll update it when I can be bothered! :thumbsup:
Nope, the dampers are the fluid filler parts which damp out the oscilation motion of the suspension system which is caused by the springs and the mass of the car reacting to an external input, i.e a bump in the road.
Shock absorbers is a common name given to the suspension components, usually the spring and damper unit together, but technically a shock absorber could be anything, including the foam padding on your seat as they absorb shocks that would be passed from the car to you.
sorry to be so anal about it but its just one of those things that gets drilled into you.
Brad =)
