Stiff Gears
johnp
The last few frosty mornings the gears have been almost impossible to select. Crunch reverse, start in second, D Declutch into first etc.
Once 5 miles have passed and the oil is circulating well, the gears are OK again.
Toyota tell me this is normal. I think it is much worse than last year.
Anyone have similar problems .
Sounds like worn synchros.....
try redline MT-90 tranny oil... usually smoothens up sticky gears :thumbsup:
yes i agree redline shockproof :yes:
its brilliant stuff not cheap though but well worth it.
i've just put it in the s15 it works :thumbsup:
Alot of us have similar problems, if you do a search you'll fit alot of threads about the same problem! :thumbsup:
