i just put a jdm starlet in my 97 paseo but its hard to find parts any where around here i say starlet people say what kind of motor is that so if anyone could help me find good aftermarket parts that would be cool im tryin to make 300hp got a 145 to :D goooo
150hp shot of nitrous to keep it reliable
forget nitrous :P
there's lots you can do pete, get a fmic, bigger turbo (tdo4, blitz k3...stock turbo just blows hot air above 12psi), decat, full exhaust, uprated manifolds (intake and exhaust), standalone or piggyback ecu, boost controller, rising rate fuel pressure regulator, uprated fuel injectors/pump, forged internals (standards dont like anything more than 21psi), uprated actuators, lightweight flywheel etc...
Youd be lucky! I wouldnt set one up to run anymore than standard, but i'm sensible and have learned from previous mistakes.
well i mean of some (admittedly, clinically insane) people running that on standard internals on a 4efte and being fine...but apparently, thereabouts or not much after is the threshold of the standard rods
EDIT: I must have been in a bad mood or something
