Wiring Help Needed Pleeeeeeeease :)
Leeky
I've put switches into my dash to control the power to the Sub Amplifier, the TV and also something else which im not quite sure what yet :lol:
on each switch there are 3 connections - Earth - Load - Supply
I've cut the ACC cable going to the TV and im going to put the switch into this wire so when i switch it on it makes the connection and lights up the green LED on the switch.
Im unsure about how to do this exactly as its been a while.
I've connected it up using the Earth and Load connectors at the moment and the switch works but the LED doesnt light up.
Anyone know how i need to do this?
:thumbsup:
Supply = live source from Battery or ignition
Load = to the tv
The earth should be going to ground or not used.
And ....
An LED is a diode and only works a specific way around :thumbsup: !
Depending on how it is set up either change the LED the other way around or change the negative and positive wires on the LED legs .... if it still doesn't work then the LED is probably a duff.
This should help !
