2 Question
viperroom_112
Hey guys , could anyone tell me were the CV joint is located , and how you go about greasing it ???
Also I am looking into getting an exhaust , does anyone have a central exit and if so roughly how much are you looking at , (cat-back) ...
David
tHINK THE EXHAUST WOULD BE A CUSTOM JOBBY, SO PROBS ABOUT £300 TO £350 ISH
CV JOINT, EASY ANSWER TAKE IT TO A GARAGE AND PAY THE MECHANIC AFTERWARDS
oops, sorry about the caps
Thats just sheer lazyness Nick!
I've never seen a central exit exhaust on a Yaris but it'd be a fairly big job I reckon coz the mounts, etc would have to be custom made and welded to the car to hold it. Have a look at the Envy sports cat and mid section. I think thats approx £350 with a little bit more to get it fitted. Heard many a good thing about this system and team it up with a cheap after market back box and your laughing!
They only fit T-Sports though! :thumbsup:
CV Joint.. Take the wheel off and you will see a rubber gator, remove the clips on the edge nearest the hub(use a set of snips) put in some grease and then thoroughly degrease the bit where the rubber gator sits then pull the gator back on and secure it with a cable tie.. jobs a goodun.
Thanks Ryan!! Don't go for the Envy sports cat and mid section!
You should use special grease for CV joints..................not the normal general purpose grease :thumbsup:
Why would you ever need to grease the CV joint ? Unless the boot is ruptured and then you would require a replacement which is fiddly and messy.
Not sure about Yaris but some split from the wheel and others from gear box.
With a centre exhaust on the Yaris bare in mind, the wiper is not centrally mounted so it may look odd on the context of the car.
I never actually thought of that , it might look totally off then . Will need to look into it more !! David
Probably best to do a photoshop, maybe the same style as the lupo GTI would suit it, sort of twin centre,
will do photoshop later on if i get through this work!!!
Nick
try find pics of eithier pascals car or echoRS's cars im pretty sure one of them if not both have the TTE borla centre exit exhaust
Aye, Pascal has the TRD Borla centre exit exhaust and I reckon it looks spot on! :drool:
cable tie.. metalclipthingofsimilarnamewhicheludesmeatthemoment.. same thing innit :lol:
Powerflo or similar will do a bespoke system with a mid exit - its all down to what you want to pay.
Envy use a local place in newcastle - they fabricated my yaris mid section, the missus's mr2 twin 4" exit system and my pajero custom backbox - all excellent quality and absolutely no hassles.
At the end of the day - you get what you pay for...
