:help: Hi,
I put a post up a couple of days ago asking if anyone had a translation of the fuse boxes in an Emina. Well I have tried every fuse in both boxes and none are blown. I don't have any front lights headlights or high beam and haven't got Hazards either indicators are fine and when I set the alarm they flash okay....the only thing I can think of is possibly a relay......Can anyone help me identify which relay I should be looking for???? Many thanks
IF YOU PM ME YOUR FRAME AND MODEL NUMBER I COULD CHECK FOR YOU .USING MY TOYOTA EPC
GT4
Thank you I'll try and work it out and see what I can do. Would the head lights and hazard lights be on the same circuit??
if the headlights are not working but the rear lights are i doubt it will be a fuse , afaik lights are set up as SIDES ie - left and right , rather than front and rear - for safety issues .
being on the same circuit ? who knows .
i'd personally pull and check every single fuse i could find , you just never know , whats joined with what as far as electrics go.
