Steering Problem
rick345
hi there
i have a 1990 celica st182 and for the last day or so i have been getting a strange feeling from the steering wheel the only way i can describe it is that the N/S front wheel feels as so it wants to detach it's self from the car and the car seems to wonder kind of tram lining . i have had the car jacked up and checked both sides for any play in the componants and can't see or feel anything strange also i have checked the tyre pressures and wheel nut tightness today and had 4 wheel alignment done a few months ago.
it's getting me slightly worried
is there anything else that i could of over looked or i could check
many thanks rick :thumbsup:
If the wheels arent wobbling at all and your tyre pressures are fine, maybe suspension related?
once got a stone trapped in a suspension spring and that messed with the cars handling.... was a big stone mind .... and it was also very hard to see as it was tucked away behind things.
gl finding and sorting the prob :)
i had aproblem with my steering [only when wet] so i had my belts changed,not done it since[fingers crossed] while they were being done they found an oil leak or power steering pump leak,which was near the belts so that might of caused it.having it sorted after me holiday :(
